S20 FE media picker battery drain
(Topic created on: 09-20-2024 07:21 AM)
harshmishhra
Any guess what's this "Media picker" draining battery in SAMSUNG? Turned of sync and everything but nothing seems to work although "Contact storage" stopped draining battery
10 Comments
Oneui_new
When we set ringtone from any mp3 file it uses sound picker. Exactly don't know about media picker. Have you installed any app regarding photos and gallery?
harshmishhra
Maybe but I haven't used any thirdy party ringtone via app or anything.
harshmishhra
No that's all I have. Will search any other media related app or something which might be draining 1726797951832.jpg1726797951865.jpg1726797951891.jpg
Oneui_new
Ohhh reset your device once and check again.
cs_member10
Dear Samsung Member,
As per your query, we request you kindly share the log file. Also, share video clips and images for better understanding. This will help us to investigate further and resolve this issue.
Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
Mighty_Abrol
Mine too
Mighty_Abrol
Mine too
Media picker is draining too much battery
harshmishhra
I couldn't find a solution. Don't know what to do
Mighty_Abrol
Its samsung
Keep hope
Lets wait for an update
I had past good experiences with rectifications on the part of samsung 😊
