11-20-2024 10:21 PM in
Galaxy S- Mark as New
11-20-2024 10:45 PM in
11-20-2024 11:54 PM in
Galaxy SYou are sending image, file or video to anyone very much or you are uploading video or image to any socal media site very much. That's why it's consuming too much battery.
11-21-2024 11:14 AM in
11-21-2024 11:22 AM in
11-25-2024 09:55 AM in
Galaxy SDear Samsung Member,
As per your concern, we want to inform you that the Media Picker, the Android Library designed specifically for selecting multiple images and videos. And, the usage of the battery is different for every application, some apps consume more battery depending on the screen time, network fluctuation, refresh rate, etc. Kindly perform the following steps to resolve your issue by using the given links.
● Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
In case the issue still occurs, kindly visit the service centre for a physical inspection of your device. You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
