S20 FE 5G display replacement issue.
(Topic created on: 10-24-2023 08:29 AM)
잠셰드푸르
I have recently replaced my display from samsung they replaced it but now i am have two major issues:-
1. Flickering issue at 60hz
1. Green tint issue at 120hz
But I am bit confused as the problem does not appear in test mode (*#0*#).
Plz provide any solution to this issue
7 Comments
Devv_007
Try a factory reset or reflash the firmware.
Tried the factory reset
But didn't work
Devv_007
Then maybe its a hardware problem ,maybe issue with display port . Recheck again in service center.
Try to check in safe mode also.
May be service centre is the last option
superman7878
Amoled display flicker its normal
cs_member10
Dear Samsung Member,
As per your query, We want to inform you that you have the warranty for the replaced part so kindly visit the service center and claim the warranty they will inspect your device and fix it at the earliest. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
