S 21 fe facing lot of signal problems
(Topic created on: 12-21-2024 09:27 PM)
santro11
My mobile signal strength is very poor
7 Comments
Shrinag
reset the network setting in phone.
santro11
Old method, I did it already
SmartBoy5204
Check Network settings and check hardware damage
goodthings
Please reset network setting of both Sim one by one and than reset all settings of your's device in general management settings also Flight ✈️ mode on n off one time also restart your's device without any Sim in slots also interchange Sim in slots also turn off power saving mode then try to it's again. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
Your's most welcome to here.
cs_member10
Dear Samsung Member,
As per your concern, we would request you to kindly visit this mentioned link to resolve your issue by using the below given link.
● Galaxy device network issue: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-smartphone-how-to-optimise-network-...
In case the issue still occurs, kindly visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
Tny278
Same issue i am facing after late December update and going through constant struggle tried everything nothing works
