S 20 FE 5G speaker problem
(Topic created on: 10-02-2023 02:13 PM)
Suman_Laha
Hi ,
I am using the S 20 FE 5G from 4 months, but now my phones speaker got distorted in full volume..
It is really a bad experience from a premium phone & also from on a S series phone .
What i can do now samsung please reply
cs_member10
Dear Samsung Member,
As per your query, we would request you to kindly perform the following steps to resolve your issue.
Clear Sound Picker data: Settings>>Apps>>Filter and Sort>>Enable "Show system apps">>Ok>>Search Sound Picker>>Tap on storage>> Clear data of Sound Picker.
Clear SoundAlive data: Settings>>Apps>>Filter and Sort>>Enable "Show system apps">>Ok>>Search SoundAliver>>Tap on storage>> Clear data.
Clear Adapt sound data: Settings>>Apps>>Filter and sort>>Enable "Show system apps">>Ok>>Search Adapt Sound>>Tap on storage>>clear data
Reset app preferences: Settings >> Apps >> Three dots (Appearing at the top right corner) >>Reset app preferences >> Reset
Reset your device: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-mobile-how-to-perform-a-factory-res...
In case the issue still occurs kindly visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
