Problems facing after updating for one ui 7
(Topic created on: 05-04-2025 07:03 AM)
piyushxyx
Updated for one ui 7 and facing high battery drain a little lag too
5 Comments
KunteAmith
Hello there battery drain and heating issues are common in samsung phones after a major update. The reasons are as follows
1. Even after your phones turns on after completing updates, it's still not completely don't with the task and keep doing it in background., hence excessive battery drain and heating issue. Once phone heats up it thermal throttles and pauses background tasks to help the phone cool down so its still not complete and it trys again later causes phone heat up again. For this what I do is reboot my phone a few times which helps speed up this process of background optimisation and also helps clear temporary files.
2. 2nd most common reason is a few files and processes of previous version of OS is still in catche memory which keeps conflicting with new OS files causing slowdown and heating., for this issue I boot my phone in recovery mode, then go and clear catche memory. After this it takes some time to load some apps but heating issue and battery drain and sluggish behavior of your phone should be fixed. If this doesn't fix the issue then you need a factory reset for your device.
3. Samsung phones in general as for as the devices I have used are bad at thermal management. Especially in summer season when ambient temperature in india is 35 degree to 42 degree makes heat deception a nightmare for these phones., try to remove you phone case during heat use and charging to help phone to cool down faster.
Hope this helps you with your issues
scamsung-user
Samsung ️ Scamsung
cs_member8
Dear Samsung member,
9. Reset the device:
IMPORTANT:
• For this:
goodthings
Kindly complaint to Samsung customer support through Samsung Members App as error report also send log files Along with this error report for this issue and wait for next update may be fix it by Samsung team soon. If you like please accept as a solution it's help to others users also,click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
Your's most welcome to here.
