Resolved! Solved
Battery icon missing in s23
(Topic created on: 05-04-2025 04:24 PM)
golu5677
Beginner Level 4
After updating to Oneui 7 battery icon is missing.
GreenMonkey
Download good lock , from there you can enable it
6 Comments
sayeedAshrafi
Expert Level 3
Achi baat hai na phone kabhi bi off nahi hoga ab aapka
GreenMonkey
Nilesh_Shah
Seems like your phone has no battery 😂 😂.. just joking bro..
I feel for you 🙏
Restart the phone. If that doesn't solve, wipe cache partition.
goodthings
Kindly use Good Lock App and enable it's. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
Your's most welcome to here.
cs_member10
Dear Samsung Member,
We request you kindly share the log file. Also, share the same images for better understanding. This will help us to investigate further and resolve this issue.
To share the log file: Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.
