Problem with s9 plus
(Topic created on: 08-29-2020 11:19 PM)
vyash
Dear Samsung Team,
I am facing an issue with my s9 plus. It's screen is flickering continuously,  my phone isn't damaged.
It is not even dropped once in 2 years nor it has gone in water even then I am facing such problem.
Service centre is charging 17000 for it.
They suggested to write to you about this concern and said maybe Samsung team will help me out.
Please look after my issue.
Thanks
Ehsank
to auto brightness disable kar k check kyie kya?
Not applicable
auto brightness disable karke to koi problem hi nehi hain ...Matlab isi level pe brightness rakhke disable kia to problem nehi koi ....lekin brightness low karta hoon to same problem na ...jo nehi hua aaj tak
Ehsank
to fir service centre hi visit karna sahi hoga shayed
Not applicable
service center visit karke kya hoga ..uohi se to software install kia ..sab s9 me ekhi problem...ie
1. You can write an e mail to - servicehead.in@samsung.com.
If not satisfied with the response or reply you can escalate it to Samsung CEO at https://www.samsung.com/in/support/write-to-our-ceo/
vinaykumartiwari
Problem with s8
Dear Samsung Team
Please send me upgrade 10 version glad to Request you
Not applicable
and for mr.vyash ....better reinstall software from service center and check...because sometimes software update via mobile data or wifi also can create those issues where actually and recommended method is to flash that firmware by Odin or through samsung service center or install software via smart switch
Not applicable
lol lagta hai samsu ka software update jhol se jada kuch nahi hai
I am facing this display issue since August security update on s10 plus, Samsung should own the responsibility that this is due to software and not hardware. This could be a reason for me not to buy Samsung if this doesn't resolve in the next update, causing using yellow tint screen is so annoying.
debjit09
facing same problem in my s9
