Problem with s9 plus
(Topic created on: 08-29-2020 11:19 PM)
vyash
Dear Samsung Team,
I am facing an issue with my s9 plus. It's screen is flickering continuously,  my phone isn't damaged.
It is not even dropped once in 2 years nor it has gone in water even then I am facing such problem.
Service centre is charging 17000 for it.
They suggested to write to you about this concern and said maybe Samsung team will help me out.
Please look after my issue.
Thanks
22 Comments
Ehsank
not only s9 several other ser facing this issue wait for update and meanwhile send feedback to Samsung by using "Get Help" section
Not applicable
but I am getting a serious issue in s9 ... I updated this last August security patch from service center as usually I do ....everything is fine but somehow I am feeling device brightness not up to the mark as previous security patch was ....in 30% brightness also screen looks like dim ...i have no display issue clear screen this time but display brightness is dim like 👌 aab isko bataye to kise bataye 🤣😅 sab to robot jo humesha 2 hi chiz bolta hain factory reset karo ya next security patch ka wait karo
Mene August security patch update hi nhi kiya pta nhi kya ho jaye mere S9+ k saath 😂
Darr lagta hai ab to update se .
Not applicable
accha kia ....waise display isbar bahut clean hain ...but dim like display in little more brightness also ....ie issue pichli update me nehi tha
Ehsank
dim light hamesha hi rahta hai ya fluctuate hota hai
Ehsank
yes service centre replied in 3way
safemode
reset
wait for next update😁😁😁
Not applicable
nehi fluctuate nehi hota ..uo sab issue nehi hain ...just little high brightness me display brightness thoda kam lagraha hain
Not applicable
ie dekho itna brightness rahe to display sahi aa raha ...isse thoda kam hua to display brightness lag raha hain dimming like👉 jo pahele wala security patch me nehi tha
Not applicable
are service center ka uo robot hain ....nehito kabhi kisiko bolta hain kya iris biometric ka screenshot do 🤣🤣🤣🤣🤣🤣
