Resolved! Solved
Problem with AOD clock
(Topic created on: 12-24-2025 02:55 PM)
hharshk
Anyone with S22 ultra facing problem with their AOD clock where the color of lock screen clock is adaptive to wallpaper but on AOD, the clock color remains default i.e. grey whereas it also previously matched with wallpaper, facing this problem on my S22 Ultra for months now
2 Solutions
goodthings
Kindly complaint to Samsung customer care support through Samsung Members app as error report also send log files along with this error report for this issue and wait for next update it's maybe fix by Samsung team soon. If you like please accept it's a as solution it's help to other users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
Please go to main page of Samsung Members app, click on support, click on feedback, click on error report then follow instructions on the screen. Log files automatically send by system immediately after the send error report but don't close Samsung Members app during this process until complete. If you like please accept it's a as solution it's help to other users also, click on 3dots in my reply section and click on accept solution. Thanks.
8 Comments
goodthings
goodthings
You're welcome to here.
hharshk
Thanks, will reach out to support. Just wanted to know how do I extract log file for this
goodthings
hharshk
Able to give a feedback with logs and documentation through this method, let's wait for the outcome. Thank you
goodthings
You're welcome.
cs_member10
Dear Samsung Member,
We request you kindly share the log file. Also, share the video clips and images for better understanding. This will help us to investigate further and resolve this issue.
To share the log file: Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.
hharshk
Feedback with supporting docs already sent to customer support, thanks
