10-24-2024 10:31 PM in
Galaxy S- Mark as New
10-24-2024 10:53 PM (Last edited 10-24-2024 10:54 PM ) in
10-24-2024 10:54 PM in
10-25-2024 09:20 AM (Last edited 10-30-2024 08:28 PM ) in
Galaxy SDear Samsung Member,
As per your query, we would request you kindly perform the following steps to resolve your issues.
● Kindly check first if there are any broken camera lenses or scratches on the camera, no laminated or tempered glass is pasted on the camera if not then check after the camera lens cleaning.
● Use a microfiber cloth or a cleaning wipe. Gently remove the fingerprints, dirt, and dust from the camera lens.
● Reset the camera settings: Home screen tap on Camera>Settings>Reset settings>Reset.
●Clear camera application data: Apps>Camera>Storage>Clear Data
●Check app cache: Settings > Apps > Camera> Storage > Clear Cache.
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Compser> Select error report> select the appropriate issue category> Type your query and send.)
