08-28-2024 02:22 PM in
Galaxy S- Mark as New
08-29-2024 10:40 AM in
Galaxy SDear Samsung Member,
As per your concern, we would request you to kindly perform the following steps to resolve your issues.
Galaxy device auto restart issue: Kindly use a genuine Samsung charger.
We always recommend using a genuine Samsung charger for charging your device.
There are two methods to disable the auto restart function.
1- Tap on Settings> General management>Reset > Disable Auto restart (if enabled)> Auto restart disabled.
2- Tap on Settings> Battery and device care> Three dots> Automation> Auto restart at set times if enabled.
If you are facing this issue after installing any new application then uninstall that application.
Tap on Settings> Apps > desired app> Uninstall> Ok.
Galaxy device freezing issue: Kindly check the space on your device:
Path: Settings > Battery and device Care > Storage
To improve the device performance there should be sufficient space.
Kindly check the RAM in your device:
Path: Settings > Battery and Device Care > Memory
The device's RAM should be free to improve performance. So clear the RAM once a day.
Clear app cache through Device care:
Tap on Settings>Device Care> Storage> Clean Now.
Is there any unnecessary application running in the background?
Kindly close the background running applications in the device (Tap the left side key & close the background running application).
Kindly uninstall that application by following the below steps and check once as the issue might occur due to third-party applications: Settings> Apps> Select the third-party application from Apps> Uninstall.
Kindly check if you are using a memory card on your device.
If you are using the memory card on your device. we will advise you to safely remove it from your device. For this follow the below steps:
Step 1: Before removing the memory card, first, unmount it for safe removal.
On the Home screen, tap Apps > Settings > Device maintenance > Storage > More option > Storage settings > SD card > Unmount. Insert the ejection pin into the hole on the tray to loosen the tray.
Note: Ensure that the ejection pin is perpendicular to the hole. Otherwise, the device may be damaged.
Step 2: Pull out the tray gently from the tray slot.
Step 3: Remove the memory card.
Step4: Insert the tray back into the tray slot
Note: Please ensure that the memory card is not removed while the device is transferring or accessing information. Doing so can cause data to be lost or corrupted or damage to the memory card or device.
Samsung is not responsible for losses that result from the misuse of damaged memory cards, including the loss of data.
If you enabled Power Saving Mode, Power saving mode limits the performance of the device. So we recommend disabling the Power Saving mode in your device.
If the issue still occurs, please visit the service center for a physical device inspection. You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
11-22-2024 07:05 AM in
Galaxy SProvided solution is useless, i reached out to service center 3 times then too i didnt got the solution.
I’m writing to share my frustration with the recent One UI 6.1 update on my Galaxy S22 Plus. Since updating, my phone frequently freezes, lags, and restarts on its own, making it difficult to use. As a loyal Samsung customer, I expected better quality control, especially for such a crucial update on a flagship device.
I urge you to investigate these issues and release a stable fix soon to restore performance.
Thank you for your attention.
https://r2.community.samsung.com/t5/Galaxy-S/S22-plus-is-unusable-after-6-1-update/td-p/17479704?src...
