04-27-2025 02:58 PM in
04-28-2025 12:06 PM in
Galaxy SDear Samsung Member,
▶ Slow charging issue: ● We always recommend to use genuine Samsung charger for charging your device.
● Check your charging cable (USB cable) for physical damage such as wear and tear, bent prongs etc. If it is damaged, then kindly visit your nearest service center to get it replaced.
● Kindly check the charger functionality with a different device or try to charge the same device with a different charger.
● Check charging: If rating is 15W or above: Kindly try to charge the device in a non-inverter socket.
● If you using normal socket: As a safety measure Fast charging may not support, while you are using the device hence, request you to keep the device idle and check the charging performance.
Note: Kindly open Device care from settings > Battery > Please tap on three dots (more option) at the top right hand side > please select settings > enable fast cable charging.
For Android 11: Kindly open Device care from settings > tap on Battery > tap on More battery settings > Fast charging > Turn on.
● Kindly follow the standard charging procedure. i.e. please charge the device in switched-off condition for 10 minutes.
● Turn off Wi-Fi, GPS, Bluetooth, etc.
Turn off unused functions like Wi-Fi, GPS, Bluetooth, and location settings when not using them: On the home screen swipe down the notification panel > Turn off Wi-Fi, GPS, Bluetooth, and other connectivity features when not using them.
● Avoid usage of mobile phones during charging. Usage of the mobile phone when charging may cause slow charging issues. So we recommend you avoid the usage of the mobile phone while charging.
▶ Battery drain issue: Note: Charge in one go instead of charging many times as it affects the life span of battery and battery performance.
2. Check device network fluctuation. Avoid usage in areas with low network/fluctuation.
3. Reduce the display brightness level or set the device to auto-brightness mode.
4. Adjust screen timeout settings: Go to Settings > Display > Screen timeout > Select the minimum screen timeout.
5. Check which application is or interface is using more battery from device care and try to update app or avoid using that app.
6. Close background running apps.
7. Turn off auto sync of e-mails, app data etc.
8. Update the software if available: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-smartphone-how-to-update-software/
9. You can reset your device by following the steps.
3. If you do not remember password then advise to reset (Forgot password) your Google account.
