S23 battery drain
(Topic created on: a month ago)
ahmed080723
Following the One UI 7.0 update, several Samsung S23 users, including myself, have observed a significant decrease in screen-on time, from approximately 6-7 hours to 3-4 hours. This necessitates charging the device two to three times daily. Samsung should investigate and address this issue.
3 Comments
cs_member10
Dear Samsung member,
9. Reset the device:
IMPORTANT:
• For this:
• Open Gmail (https://accounts.google.com/servicelogin) > forgot password >Select ""try another way"" > Next > Enter a new password > Next.
Please follow the below steps to reset the device: Settings > General Management > Reset > Temporary cloud backup or External storage backup > tab on Factory data reset (This will erase all data, including files and downloaded apps)
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send).
goodthings
Kindly complaint to Samsung customer support through Samsung members app as error report also send log files along with this error report for this issue and wait for next update maybe fix it by Samsung team soon. If you like Please accept as a solution it's help to other users also,click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
You're welcome to here.
