06-03-2025 09:11 PM in
Galaxy SBasically, your screen just stops responding during app animations. You tap something, the animation starts, and you are stuck waiting for it to finish before you can do anything else.
It’s one of those bugs that sounds minor until you actually experience it. Try using the Gallery app – you know how you normally just rapid-fire through photos? Well, forget about that. Every transition forces you to wait, and it gets old really fast.
We have seen a similar issue in previous One UI versions. It’s like Samsung can’t figure out how to make the animations look good without breaking basic touch responsiveness.
The whole beta process runs through the Samsung Members app, which means the company is waiting for bug reports from users like us. It works, but it also means problems like this might stick around for weeks while they collect feedback and figure out fixes.
For developers or tech enthusiasts who don’t mind some rough edges, it’s still worth checking out for the new features. But if you need your daily driver to work smoothly, maybe wait for the stable release – assuming Samsung actually fixes this stuff by then.
06-04-2025 12:00 PM in
Galaxy SDear Samsung Member,
We would like to inform you that, at this time, there is no official information available about the release of the UI 8 beta update.
We recommend that you stay updated through the Samsung Members application, where you will be notified as soon as it is officially launched on Samsung devices.
Additonally, We are taking your feedback regarding this matter and will take it into consideration for future updates.
