Noticed gap between Frame and Screen on S23 ultra
(Topic created on: 04-07-2024 10:31 PM)
Malick17
I just noticed a gap between Frame and Screen of my s23 ultra on Right Side. There was a lot of dust inside and even a sticky note paper gets in easily.
The left side has no gap. 😔 Now I'm wondering if my phone is even waterproof or not.. 😞
Anyone here with S23 Ultra, if any please let me know if it is only with my phone.
17 Comments
Subhro99
This is a very unfortunate event. If that happens automatically without any physical damage to the frame or screen, and it's under warranty, it will be fixed easily. Just reach out to your nearest Samsung Mobile exclusive service center or Authorised one.
Visit:- https://www.samsung.com/in/support/service-center/
If you find the solution helpful. Pls mark it as "Accepted solution" by clicking on 3 dot with the comment.
Malick17
I visited service center but they said it is normal. Do you have any knowledge about it if it is normal or not?
Subhro99
No it's an issue. And it's absolutely not normal. It can damage your phone display and your phone's waterproof capability.
It can also happen if your phone's battery is swollen and it's pushing your display outside. If you need further help. Text me in the community.
pravinn4
Beginner Level 4
I also have panel gap between the screen and frame at bottom in my s23
Akilan_R
Go to service center they fix screen
sahunaveen
Bro this problem is because your device is heating also from charging port side. Mere me to baar baar gap aa jata hai sahi kabane par bhi.
Malick17
Apkay pass konsa phone hai, aur iska kya solution hai?
sahunaveen
M20 & solution me shop me bahut baar Kara Chuka hu sayad unka gum sahi na ho ek baar pehle shop se karao agar out of warranty hai to nahi to phir service centre.
Ronkzz
check battery physically
if it is swollen..
