Always on display not changing position.
(Topic created on: 05-05-2025 02:13 PM)
PraneethBobba23
Hi, I recently purchased Galaxy S24 Ultra.I use Always on display with setting 'Always'. I noticed that AOD (clock and date) not changing its position. It is always in the same position. So, my concern is Amoled screen pixel burn, if it stays constant like that for hours.
 Is there any setting I have to change(tried all).Please help me with this.
 Thank you.
12 Comments
4y🔥let's not k❤f🔥 up
Deepray13
Sell your mobile and buy 🍎
Instead of buying 🍎, I would rather don't use Smartphone..🙂
Kabbya_Singha
S24 ultra display hardware is capable enough to keep the clock at a same position. S23 series had that issue. That changes the position every time you lock the phone
Ok. You mean same position AOD doesn't affect S24 ultra screen even with show always setting on..?
Kabbya_Singha
No. It's hardware is capable to keep the clock and now bar at same position
Ok,but what about screen burn if they stay in same position for hours/days..?
Kabbya_Singha
It might. That's why i use tap to show aod. It's battery efficient and no tension for burning😃
Okk😊. But we are very much habituated to always AOD since so many years. Even now my wife uses S20 FE with One Ui 5 with shifting AOD every minute and on locking phone.I used Oneplus with good AOD functionality. I didn't expect this in S24 ultra. I think it is software flaw in One UI 7 that samsung should address Asap.
