Network problem in samsung galaxy s21fe 5g
(Topic created on: 02-08-2023 08:05 AM)
rsaini
Very poor internet reception in indoor in samsung galaxy s21fe 5g. Even a Chinese branded 10k rupees phone have -85 to -90 signal strength in same place. But so called Fan Edition having -110.
I am regretting after purchase samsung's phone.
26 Comments
satdidoS24
TRUE same here
arvi2022
Samsung now very worst network provided
piyussh07
How can one check this?
Is this only applicable for Mobile data?
Wifi connection is one of the best I've till now on S21FE :)
Don't know about Network reception, that's why i asked.
rsaini
Yes go inside in your house or somewhere indoor and use mobile data then you can see that. You can use internet after using airplane mode for a limited time then again you need to use airplane mode.
You can compare this by using other companies smartphone side by side and see the difference
Bibhu1212
Bro these days now the internet providers like jio airtel gone very poor upload speed specially in low areas my mom's mobile os realme c2 i brought the mobile in july 2 2019 same problem network issue with the mobile the network totally depends on your tower and consumer in your area
rsaini
Bro i tested all methods. You don't know. Even i checked this with 3 smartphones at a same network, same place, even samsung galaxy s20fe have better internet speed at same place.
Bibhu1212
Okk bro so bro you must go to the service center
rsaini
I have no hope from these service centers. They give your smartphone after reinstall the software and that is. But i will go there ones. Samsung should take this seriously because we spent a huge amount of money on this. They should fix it with software update.
Bibhu1212
My mobile is Samsung a12 when i go to bhubaneswar my network is stable even i play pubg on my airtel sim my ping is literally 40 50 ms and when i come area the ping is 400 to 600 ms
