Network problem after one ui 7 upgrade on my s24+
(Topic created on: 05-10-2025 01:21 PM)
vp123
Beginner Level 3
Im facing network stability issues with my s24+ phone from starting only but it became worsen after updating to one UI 7... I tried every possible settings none of them are useful. Meanwhile my another phone with same sim works fantastic... Samsung!!!!!
4 Comments
goodthings
goodthings
Your's most welcome to here.
cs_member8
Dear Samsung Member,
● Kindly check the device in different locations/network coverage areas.
● Check Mobile Network: Settings> Connections>Mobile networks> Network mode> Select 5G/LTE/3G/2G (auto connect).
● Check Network Operator: Settings> Connections> Mobile networks> Network operators> Select automatically.
● Kindly check the same SIM card in another phone or another SIM card in the same phone to verify the issue.
● Kindly try to contact the service provider once.
● Update device software (If available): Settings > Software update > Download and install > Checking for software update > Software update available > Download > Downloading updates > Install now.
● You can reset your device by following the steps from the below link.
If the issue persists, kindly report the problems with a log file. To share a log file, Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.
vp123
Beginner Level 3
Tired everything. No use
