Need help
(Topic created on: 10-01-2025 03:05 AM)
Priyansh95
Heyyy I bought my s24fe 2 months ago i wanted a feature in my AOD like bro i saw in other samsungs their AOD is cool like it just dims the wallpaper down but mine only makes black screen help me pls? and yea one UI 8 has a special animated new clocl which isn't working properly probably bugs and umm the breif feature is cool af but i still find something missing in it like i only get weather info and idk more but it has potential for more, for Now please help me with the AOD
8 Comments
Samsung_OneUi
You have FE phone. It is not a flagship device. The feature you are asking for is coming in S24 like flagship device not fe.
Priyansh95
So there's no way i can do that? is there any chance in fututre?
Samsung_OneUi
Yes but less possibility
Priyansh95
Roro_Zoro
Mine as well the new clock feature is not working. Mine is s24 ultra
cs_member10
Dear Samsung Member,
We request you kindly share the log file. Also, share the video clips and images for better understanding. This will help us to investigate further and resolve this issue.
To share the log file: Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.
Priyansh95
I used these for wallpaper but the clock feature only worked on lockstar and just after I save the customization the clock becomes normal not the animated and when the AOD comes the animations won't work at all idk if it's a bug or what but in my friend's s24 has also the same bugj5ndMXiqjv.jpgbFdNUpHeUS.jpgQkcn7DWWdP.jpgXGz7M81aaw.jpg
Priyansh95
And yea There's also a issue like my mic are just finee but whenever I play game which needs mic the mic become very bad likee my teamates says that my voice quality is very poor and on calls the quality is good
