01-23-2021 10:04 PM (Last edited 01-24-2021 09:19 AM ) in
Galaxy S- Mark as New
01-24-2021 06:49 AM (Last edited 01-24-2021 06:51 AM ) in
01-24-2021 09:04 AM in
01-23-2021 10:14 PM in
Galaxy Sand you cant compare samsung and oneplus
oneplus is a poor camera quality poor build quality Chinese phone
samsung is reputed brand
ager s20 plus heat bhi hota ho fir bhi onplus ke sabhi phone se lakh guna acha h
01-23-2021 11:25 PM (Last edited 01-23-2021 11:26 PM ) in
01-23-2021 10:18 PM in
Galaxy SFacing it now on S20+, when i do multi tasking for more than 15 mins, camera front wide angle yes.
I did factory reset after 2.5 and 3 update. Still same. I feel i made a mistake in buying it 😕. Even after recent update its still the same. Even i can feel warm after using a case. Im using it since October. Battery life is decent for me, getting 7hrs 15 mins on previous a11 first stable build, but after this weeks bug fix, im getting 45 mins extra SoT
01-23-2021 10:41 PM in
Galaxy SA. Wipe Cache Partition.
Steps to perform.
1) Turn off the device.
(Connect with type C cable and connect withpc/laptop/type C earphone only for Android 11 )
2) Press and hold the Volume Up key and the spower button.
3) When the Android logo displays, release all keys.
4) Press the Volume down key to navigate and select "Wipe cache partition".
5) Press Power key to select. When the wipe cache partition is complete, Select Reboot System.
6) Press the Power key to restart the device.
B. Reset App Preferences.
Settings >Apps> Tap on Top Right 3Dots and select Reset App preferences.
C. Go to settings >general Management >reset>reset settings.
01-23-2021 10:42 PM in
Galaxy S1. Settings>Connection>more connections settings> disable nearby device settings.
2. Settings>>Location>improve accuracy >disable
A. Wifi scanning
B. Bluetooth scanning .
And enable these 2 options.
A. Adaptive battery
B. Put Unused Apps to Sleep.
4. Long press on each app specially 3rd party app(LIKE FACEBOOK, YOUTUBE) and rarely used apps and also ON "GOOGLE APP" as well, then click on>app info> go to these 3 options below on by one
6. Go to settings > Google > on device sharing> check which 3rd party apps present there for e.g. if you use paytm , paytm will shared data to show recommendation and suggestion which also cause battery drain
7. Go to settings > account and backup> account > check which app syncing automatically there, and if any app which not necessary to auto sync then click on it and "disable sync"
8. Go to settings >apps>search "weather" >click on settings icon right side > change "auto refresh" settings as per your requirements and disable some unnecessary reminder. ( due to auto refresh it continuously consuming battery)
10. Settings>Google >click on 3dot at right top corner>usage and diagnostics >off this option.
01-24-2021 10:21 AM in
01-24-2021 12:56 PM in
Galaxy SGetHelp>>SendFeedback>>ErrorReport/AskQuestion>choose appropriate section
