Multi touch problem
(Topic created on: 4 weeks ago)
brother71
It cannot register multi touch properly. I notice the issue whil playing game
I downloaded those multi touch tester and if I put my left thumb and 2 fingers from my right hand then place them on the screen at the same time, it does not always register 3 touches. If you move your fingers then it will.
Anyone have this issue?
Could it be another app that is causing the issue?
Faulty screen?
3 Comments
cs_member10
Dear Samsung Member,
We request you kindly share the log file. Also, share the video clips and images for better understanding. This will help us to investigate further and resolve this issue.
To share the log file: Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.
goodthings
Kindly complaint to Samsung customer care support through Samsung Members app as error report also send log files along with this error report for this issue and wait for next update maybe fix it by Samsung team soon. If you like please accept as a solution it's help to other users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
You're welcome to here.
