10-06-2024 11:36 PM (Last edited 10-06-2024 11:38 PM ) in
10-07-2024 09:30 AM in
Galaxy SDear Samsung Member,
Galaxy device heating issue: https://www.samsung.com/in/support/mobile-devices/why-the-device-heats-up-during-use/
Galaxy device slow performance issue: https://www.samsung.com/in/support/mobile-devices/why-is-my-phone-slowing-down-and-how-can-i-speed-i...
Clear app cache through Device care:
Tap on Settings>Device Care> Storage> Clean Now.
The clear cache memory of a particular application:
Settings > Apps > Now pick the app that you like to clear off the cache memory > Storage > Clear Cache.
Kindly check if you are using a memory card on your device.
If you are using the memory card on your device. we will advise you to safely remove it from your device. For this follow the below steps:
Step 1: Before removing the memory card, first, unmount it for safe removal.
On the Home screen, tap Apps > Settings > Device maintenance > Storage > More option > Storage settings > SD card > Unmount. Insert the ejection pin into the hole on the tray to loosen the tray.
Note: Ensure that the ejection pin is perpendicular to the hole. Otherwise, the device may be damaged.
Step 2: Pull out the tray gently from the tray slot.
Step 3: Remove the memory card.
Step4: Insert the tray back into the tray slot
Note: Please ensure that the memory card is not removed while the device is transferring or accessing information. Doing so can cause data to be lost or corrupted or damage to the memory card or device.
Samsung is not responsible for losses that result from the misuse of damaged memory cards, including the loss of data.
If you enabled Power Saving Mode, Power saving mode limits the performance of the device. So we recommend disabling the Power Saving mode in your device.
You can reset your device by following the steps.
However, kindly report the problems with a log file regarding brightness issue. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appriopriate issue category> Type your query and send.)
10-07-2024 10:32 AM in
Galaxy S- Mark as New
10-07-2024 07:25 PM in
Galaxy SHow to all apps caches clear in one time?
