Mobile Signal Strength Problem
(Topic created on: 07-10-2024 09:57 AM)
Sàfí
My Galaxy S23 Ultra showing very weak signal strength in jio Sim. No matter wherever I go, the network strength remains same. I also try it with Airtel sim but I think this is an issue. Can anyone tell me how to fix it?
Low signal 📶
8 Comments
NripenGhosh
My s24 ultra also same issue with airtel
Sàfí
Oh
vkindian26
A55 5G SINHNEL STRENGTH WEAK
Sàfí
Oh
vkindian26
Yes you are
Faiyaz13
Kindly reset mobile network it helps
Sàfí
Ok
goodthings
Please reset network setting of both Sim one by one and than reset all settings of your's device in general management settings also Flight ✈️ mode on n off one time, restart your's device without any Sim in slots, interchange Sim in slots, turn off power saving mode then try to it's again. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
