Network issue with S22 Ultra OneUI 6.0
(Topic created on: 02-15-2024 06:02 AM)
gopmrx
After updating to OneUI 6.0 my both Airtel and Jio shows network issues all the time. I always have no service problem.
I have this issue on both the sim cards Airtel (Sim 1) and Jio (Sim 2). I updated Airtel SIM card as well. Anyone else experiencing the same?
Update: 16/02/2024 at 13:30
I started using primary sim Airtel as eSIM. Issue not resolved. Also, I noticed this problem where signal strength is little lower than high signal areas. I get network only where signal strength is high or complete 5 bars.
34 Comments
Prashantbgh
Reset your network setting
gopmrx
Not working.
Mayur000
Goto settings - general management
Click reset
Then choose "reset network"
And wait one minute.
If priblem not solved then
Then remove sim tray,
Try to again reset network
Then after one minute
Switch off phone
Insert sim tray.
Switch on phone.
gopmrx
Nothing is working.
Hi,
By any chance were you able to resolve the issue?
There are a lot of people including me facing exactly the same problem. Unfortunately none of recommendation by Samsung or other people is worked. It seems an software error and must be fixed at the soonest, The phone is useless now...
gopmrx
Very true 😞
Hi! By any chance were you able to resolve this issue? 😪
Mayur000
Then try by service menu.
Dial
*#0011#
Check sim info..
