Low Speaker sound in S23 Ultra
(Topic created on: 04-19-2024 11:27 AM)
Jittiॐ
Hello Friends,
My Samsung S23 Ultra speaker sound has been decreased after One UI 6.1 update, earlier it was very loud that I haven't used its volume more than 60% but now after 100% volume the sound is that much low I have to hold phone near the ears to hear sound. Any suggestions or solution please.
6 Comments
Madĥav
Only one. Restart 😅
Jittiॐ
I already reset the phone but issue is not resolved yet.
cs_member10
Dear Samsung Member,
As per your query, we would request you to kindly perform the following steps to resolve your issue.
Disconnect all accessories
Disconnect anything plugged into the headphone jack like, selfie stick, headphone, Bluetooth, etc.
Remove any third-party case, protective films, or any other accessory that usually comes in contact with your device. (If any)
Check device volume settings: Please follow the below steps:
Navigate to apps screen and tap on Settings>>Tap on Sound & vibration>>Tap on Volume>>Drag the volume adjustment bar left or right to increase or decrease the device volume.
To verify, play music and check the music sound. If the sound quality is good, then your speaker is working fine.
Clear Sound picker data: Please follow the below steps.
Got to Settings
>>Apps>>Filter and sort>>Enable "Show system apps"
>>Tap "OK">>Search Sound Picker>>Tap on storage>>clear data of Sound picker.
Clear SoundAlive data: Please follow the below steps.
Got to Settings>>Tap Apps>>Tap Filter and sort>>Tap Enable "Show system apps">>Tap "OK">>Search "SoundAlive">>Tap Storage>>Tap Clear data
Clear Adapt sound data: Please follow the below steps.
Got to Settings>>Tap Apps>>Tap Filter and sort>>Enable "Show system apps"
>>Tap "OK">>Search "Adapt Sound">>Tap Storage>>Tap Clear data
Reset app preference: Please follow the below steps.
Got to Settings>>Tap Apps>>Tap Three dots (Appearing at top right corner)>>Tap Reset app preferences (It will reset the permissions of all applications).>>Tap Reset
Update device software (If Software update available): https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-smartphone-how-to-update-software/
Reset the device: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-mobile-how-to-perform-a-factory-res...
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
Samsung Customer Support.
swapnils1995
You found any solution for this sound issue???please suggest because i am also facing this problem
Jittiॐ
Still not found any solution for this..
swapnils1995
I updated to September update still no resolution. I think need to try service center visit
