Audio sound
(Topic created on: 12-08-2024 06:00 PM)
zigzagzoo
Does anyone else have the speaker issue on the s24 ultra because in my phone, the volume level is very less even at the highest level. The ringtones and alarms sound is quite less then what I thought. Any idea how to fix it?
Wodehouse
See the screen shot.
If this reply answered your query please mark my reply as "resolved" by clicking 3 vertical dots on top right of my reply. Thank you 😊1733661777516_1733661777507_0.jpg
9 Comments
MADY15387
Use good lock app
MADY15387
Sound assist will help you....if it is related to software...
Else check ur hardware in members app
zigzagzoo
I have tried everything. Doesn't work . The sound is still less
Wodehouse
zigzagzoo
I reckon there is a slight improvement. Maybe will understand better in the long run.
zigzagzoo
But the problem is, my friends have higher volume on their phone compared to mine without this setting.
MADY15387
Sardiyon me bhi kam laga ri hai...
Customer care wale bula re hain aap ko fir
Aap ho ki yahan service dhoondh re ho😂😂😂
zigzagzoo
Ab kya kar sakte.
cs_member10
Dear Samsung Member,
● Disconnect anything plugged into the headphone jack like, a selfie stick, headphones, Bluetooth, etc.
Remove any third-party case, protective films, or any other accessory that usually comes in contact with your device.
● Check device volume settings: Tap on Settings > Sound & vibration>Volume > Drag the volume adjustment bar left or right to increase or decrease the device volume.
To verify, play music and check the music sound. If the sound quality is good, then your speaker is working fine.
● Clear Sound Picker data: Settings> Apps> Filter and Sort> Enable Show system apps> OK>Search Sound Picker> Storage> Clear data of Sound Picker.
● Clear Sound Alive data: Settings> Apps> Filter and Sort> Enable Show system apps> OK>Search Sound Alive> Storage> Clear data.
● Clear Adapt sound data: Settings> Apps> Filter and Sort> Enable Show system apps> OK>Search Adapt Sound> Storage> Clear data.
● Reset app preferences: Settings> Apps> Three dots> Reset app preferences> Reset.
In case the issue still occurs, please visit the service centre for a physical inspection of your device. You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
