Speaker Issue On Call _ S25 ultra
(Topic created on: 02-07-2025 07:56 PM)
JackJoe
Beginner Level 4
In S25 Ultra, If you're on a call with the loudspeaker on and something blocks the top sensor, the ear speaker sound turns off (cut off & on), making it seem like the audio is lost.
Please check it & give a comment
5 Comments
arec
It's in all devices of samsung
JackJoe
Beginner Level 4
S24 ultra is fine
goodthings
Kindly complaint to Samsung customer support through Samsung Members App as error report also send log files Along with this error report for this issue and go to service center for resolves this issue. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
Your's most welcome to here.
cs_member10
Dear Samsung Member,
● Disconnect anything plugged into the headphone jack like, a selfie stick, headphones, Bluetooth, etc.
Remove any third-party case, protective films, or any other accessory that usually comes in contact with your device.
● Check device volume settings: Tap on Settings > Sound & vibration>Volume > Drag the volume adjustment bar left or right to increase or decrease the device volume.
To verify, play music and check the music sound. If the sound quality is good, then your speaker is working fine.
● Clear Sound Picker data: Settings> Apps> Filter and Sort> Enable Show system apps> OK>Search Sound Picker> Storage> Clear data of Sound Picker.
● Clear Sound Alive data: Settings> Apps> Filter and Sort> Enable Show system apps> OK>Search Sound Alive> Storage> Clear data.
● Clear Adapt sound data: Settings> Apps> Filter and Sort> Enable Show system apps> OK>Search Adapt Sound> Storage> Clear data.
● Reset app preferences: Settings> Apps> Three dots> Reset app preferences> Reset.
3. If you do not remember password then advise to reset (Forgot password) your Google account.
In case the issue still occurs, please visit the service centre for a physical inspection of your device. You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
