Led Notification
(Topic created on: 01-28-2023 08:04 PM)
SudeepPhoju
Green led notification popsup by the side of battery in upper right corner while usimg camera and mic. If the same led notification can be use while charging it would have been better to know either the device is charging or not.🤔
3 Comments
Pratyušh
Well
When we charge our device it already shows the battery icon and it's percentage at bottom of screen
Starshiv
It is the feature of Android 12.
It was introduced for security reasons.
Whenever any app use your Camera or mic, the indicator will show you to let you know some app is using camera or mic.
cs_member8
Dear Samsung Member,
Thank you for sharing your feedback. We have noted down the feedback. We are continuously working for making our products better and more efficient.
