Lag and restart issue with s23 while using instagram
(Topic created on: 04-05-2025 02:32 PM)
sunnyZeus
Beginner Level 4
My phone's been lagging like crazy on Instagram for two days now—it freezes, then restarts after a minute. I've tried everything, clearing the cache and all that. It's gotta be a bug; fix it ASAP, it's spreading to other devices.
59 Comments
anthonyjeswin
That sounds super annoying — and you’re not the only one. A lot of users on One UI (especially S23/S24) are reporting Instagram freezing, lagging, and even causing reboots after the last few app updates. You're totally right — this feels like a bug in the app itself, possibly a conflict with Samsung’s system UI or GPU drivers.
Ritwiksondhi
Not happening on my S23 or Xiaomi Pad 6 but it is happening on my Dad's Redmi 13 pro and a friend's Moto Edge 50 Neo. Seems to be more of a Instagram/google bug.
jagbeer1
Beginner Level 5
I facing same issue while using instagram my samsung s23 freezes and restart
robinYui
Same, brother. It's really annoying ms
cortana27
Beginner Level 3
Same issues
jkoorara
Same issue i updated instagram but still issue comming
jkoorara
Mine in s23 ultra
Joni88
Mine too is freezing while using Instagram, Fix it ASAP
Samsung_Kdo5Wbg
Happening with my s23 ultra as well, tried reinstalling insta, but nothing happened
cs_member10
Dear Samsung Member,
As you have mentioned that you are facing the issue with third party apps and if your device other application working fine with mobile internet, So we would request you kindly contact the respective helpline they will guide you regarding the exact information regarding this.
However, If still facing the same issue, kindly share the log file. This will help us to investigate further and resolve this issue.
Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.)
