Resolved! Solved
Jio 5g not working in USA s23 ultra model
(Topic created on: 11-18-2023 08:25 AM)
bullet533
Jio 5g not working in USA s23 ultra model. Future me koi update se ho jayega 5g unable?
RamprasadR
Even I had the same issue activating with Jio true 5G on my samsung galaxy s23 mobile purchased from US and using it in India.
I had to reach reach samsung service center to get it flashed and get reload with latest updates. Later, I used my jio Sim on one of my 5G mobile purchased in India and got my Sim activated with theJio welcome offer and got my jio Sim activated with true5G and soon after receiving with message my jio Sim was active with 5G network. Later removed the Sim and used it on my samsung galaxy s23 purchased overseas. Now my mobile has successfully works with Jio 5G.
27 Comments
Dilli
Did you speak to jio service provider
TSR83
No use
bullet533
Yes
Saqlain49
Same problem here
Mnkpz
As per telecom operators only Indian 5g veriant phone will work 5g in indian
bullet533
OK thanks bro
arec
Jio 5g only works in india, as still it is in testing, not stable yet
KamalP12
Port your sim card
