Issues with Samsung S22 plus noise issues with outgoing calls
(Topic created on: 03-26-2022 01:12 AM)
Sameer
Bought s22 plus 2 weeks back.. Facing with some weird issue. Would appreciate if someone could assist in solving this, as solution to this is not found on you tube or other platforms.
1) Out of 10 outgoing calls from sim 1, for atleast 4 calls a loud noise comes when call is trying to connect.... but when the phone is put on speaker it vanishes.
2) tried to again call someone else with 2nd sim, same noise again ... so it's proved that it's not a network problem.
3) it happens consecutively for 3 to 4 calls then calls are normal. Also incoming calls are very normal.
4) Tried resetting all settings including network settings... also played with wifi calling ..problem still persists... even shop keeper is clueless what the issue is ..
Would appreciate if someone could help me in solving this issue, will be really grateful ..
Regards,
Sameer
15 Comments
aroraraghav
I experience same
Sameer
Which phone
aroraraghav
S22 ultra bro. Same thing what you facing.
Sameer
Any solution you have ...Customer care of Samsung has asked me to uninstall updates of Android system web view and check
sidanashubham
I haven't face this issue
aroraraghav
They asked me to do same. But I feel It should be updated via software
aroraraghav
They asked me to get the phone.
aroraraghav
They will format it I know. Only solution they have
Sameer
Hi Raghav, are you facing the same problem again ? ...in my case ...it again started after 3 days ...
