01-05-2024 09:49 PM in
Galaxy S- Mark as New
01-06-2024 09:26 AM in
Galaxy SDear Samsung Member,
As per your query, we would request you to kindly perform the following steps to resolve your issue.
Check the message center number: Messages>More (Three dots)> Settings>More settings> Text messages>Message Center>Message center number and Tap on OK.
Note: Contact your service provider to get the correct message center number.
Clear the messaging app's data: Settings> Apps> Messages> Storage> Clear data>OK> Message app data cleared.
Note: kindly contact your network service provider once to make sure there is no issue from their end.
You can check the device in safe mode and for the same mode you can tap on the given link. https://www.samsung.com/in/support/mobile-devices/safe-mode-on-samsung-phones/
01-06-2024 10:03 AM in
