Signal issue
(Topic created on: 12-21-2024 09:24 PM)
Jeeruln
Subject: Signal Issue with Samsung S21 FE (Snapdragon Edition)
Dear Samsung Customer Support Team,
I am writing to report a persistent signal issue with my Samsung S21 FE (Snapdragon Edition) device. Despite being in areas with good network coverage, I consistently experience dropped calls, poor voice quality, and slow data speeds.
Device Details:
Model: Samsung S21 FE (Snapdragon )
Issue Description:
- Poor signal strength and frequent signal drops
- Dropped calls and poor voice quality
- Slow data speeds
Troubleshooting Steps Taken:
- Restarted the device multiple times
- Checked for software updates and installed the latest version
- Reset network settings
- Cleaned the SIM card slot
- Checked for physical damage
I would appreciate it if you could look into this matter urgently
6 Comments
Shrinag
Swap SIM card once; it will be cleared.
goodthings
Please reset network setting of both Sim one by one and than reset all settings of your's device in general management settings also Flight ✈️ mode on n off one time also restart your's device without any Sim in slots also interchange Sim in slots also turn off power saving mode then try to it's again. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
Your's most welcome to here.
cs_member10
Dear Samsung Member,
As per your concern, we would request you to kindly visit this mentioned link to resolve your issue by using the below given link.
● Galaxy device network issue: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-smartphone-how-to-optimise-network-...
In case the issue still occurs, kindly visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
Jeeruln
I am doing all the things but problem not resolved 🙏
Charan20909
Bro,I am experiencing the same issue in my device.Did you find any solution for this?
