β02-21-2024 09:40 PM in
β02-22-2024 11:23 AM in
Galaxy SDear Samsung Member,
Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
Galaxy device camera issue: Check physical condition of your camera lens.
Broken camera lens>> Scratchy camera lens.
Note: Please check there is no laminated or tempered glass pasted on camera.
Use a microfiber cloth or a cleaning wipe. Gently remove the fingerprint, dirt and dust from the camera lens.
Reset camera settings:
From the home screen tap on Camera>>Tap on Settings>>Scroll up and tap on Reset settings>> Tap on Reset.
Galaxy device hang issue :Check space availability
Kindly check the space on your device:
Path: Settings > Battery and device Care > Storage
To improve the device performance there should be sufficient space.
Kindly check the RAM in your device:
Path: Settings > Battery and device Care > Memory
The device's RAM should be free to improve performance. So clear the RAM memory once a day
Clear app cache through Device care:
Settings > Device care > Storage > CLEAN NOW.
Note: To delete files or uninstall apps that you do not use anymore, select a category under USER DATA. Then, tick items to select and tap DELETE or UNINSTALL.
The clear cache memory of a particular application:
Settings > Apps > Now pick the app that you like to clear off the cache memory > Storage > Clear Cache.
Close Background Apps
Is there any unnecessary application running in the background?
Too many applications running in the background may cause the device to hang. Kindly close the background running applications in the device (''Tap the left side key & close the background running application'').
Remove third party application
Kindly uninstall that application by following the below steps and check once as the issue might occur due to third-party applications.
Step1: Navigate to Settings
Step2: Tap on Apps
Step3: Select the third-party application from Apps.
E.g. DU Recorder
Step4: Tap on Uninstall
Remove memory card
Due to some ''unauthorized'' file in memory card device performance will be slow, so if you are using the memory card in your device. I will advise you to safely remove it from your device. For this follow the below steps:
Step1: Before removing the memory card, first, unmount it for safe removal.
On the Home screen, tap Apps > Settings > Device maintenance > Storage > More option > Storage settings > SD card > Unmount.
Insert the ejection pin into the hole on the tray to loosen the tray
Note: Ensure that the ejection pin is perpendicular to the hole. Otherwise, the device may be damaged.
Step2: Pull out the tray gently from the tray slot.
Step3: Remove the memory card.
Step4: Insert the tray back into the tray slot
Note: Please ensure that memory card is not removed while the device is transferring or accessing information.
Doing so can cause data to be lost or corrupted or damage to the memory card or device.
Samsung is not responsible for losses that result from the misuse of damaged memory cards, including the loss of data.
Remove third party accessories
Due to ''3rd Party'' (Not provided by Samsung) Accessories, (Like ''Charger, USB Cable'' etc.) device might also hang. So kindly avoid the usage of these 3rd party accessories.
Disable power saving mode
Power saving mode'' limit the performance of the device. So we recommend disabling the Power Saving mode in your device.
Reset your device: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-mobile-how-to-perform-a-factory-res...
In case the issue still occurs, we request you kindly share the log file. Also, share video clips and images for better understanding. This will help us to further investigate and resolve this issue.
Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
β02-23-2024 12:01 PM in
Galaxy SThat problem only exist in s21 fe
I compared it with s20 fe and s24 .only found in my s21 fe π€
β02-25-2024 08:37 AM in
Galaxy S- Mark as New
β02-24-2024 05:00 PM in
β02-25-2024 08:38 AM in
β02-24-2024 07:35 PM (Last edited β02-24-2024 07:54 PM ) in
β02-26-2024 04:52 AM in
β02-25-2024 09:59 PM in
β02-26-2024 04:53 AM in
