Issues need to fix πŸ™
(Topic created on: 02-21-2024 09:40 PM)
CHANU_99
Some minor issues but facing always.. need to be fix πŸ™
This is Galaxy S21 FE 5G (Snapdragon 888).
Facing issues:
1. 3x telephoto lens can never focus close subject. This is working only for subjects which are far away.. If I try to focus close subject, it shifts to the main sensor or if I tap on 3x to focusing close something, it never shifts. (It's after UI 6.0) {may be this is happening on most of the S series phone having telephoto lens}
2. Selfie camera gives blurry output. If I take a group selfie, only my face is sharp & clear.. but all other's face at my background (if in little distance) are so blurry & not sharp. Also for scenery background.
3. Eye Comfort Shield never works on Lockscreen. When I unlock, it works but never on Lockscreen. (It's after UI 6.0)
4. Phone hangs/heavily drops frame while remastering a picture in gallery. Remastering animation not remains smooth & if I scroll down notification panel, it feels like 90's phone with heavy load.
5. Last 5% charge drops within 1-2min while in use.
I hope @Samsung look into these matterπŸ™
CHANU_99
Does it work for Samsung?
CHANU_99
Ha! Ho skta hai.. lekin pehle hua krte the. Aab nhi hota.. lekin agar hum use kr rhe hai, to lockscreen pe bhi essential hoga..!
CHANU_99
Hm
tusharkabir
1. turn on tracking focus. Low light me bhi issue hota hai 3x pe focus lene me. 3x lens bhut nazdik ka focus nahi leta.
2.Reset your camera setting.
3. eye comfort shield won't work on lock screen to make usable finger print sensor as this device have optical fingerprint sensor.
4.reset your phone or flash or downgrade.
5. ye to sare phone me hota hai.
CHANU_99
1. Haa bhai, UI5.1 mai lens change hua karte the, lekin aab nhi hota.. pehle mai shoot lia nazdik chiz ke 3x se.. best quality wala. lekin aab hota hi nhi. Low light ka problem pta ha, lekin daylight ka prblm hai.
tusharkabir
probably because of new ui 6.0 , report problem on samsung customer service.
Hansraj007
I also feel that after One UI 6 update camera quality is degraded
CHANU_99
Yes brotherπŸ₯² now also it can't click that jealousy level 3x portrait shoot πŸ˜’
Hansraj007
hopefully its gets fix with One UI 6.1 update πŸ™„
