How to disable notification drawer on lock screen- s24 ultra
(Topic created on: 08-26-2024 12:29 AM)
IS_S24ultra
Please tell how to disable or hide notification drawer on the lock screen for security purpose.
14 Comments
tharunok
1.hold in the middle of the lock screen.
1.1 if locked,unclock after step 1
2.tap on the icons near time.
3.Select none or icons only
IS_S24ultra
Thanks for your reply but i am concerned about the quick setting panel that displays when pulled down from the top of the screen on lock screen. Can it be hidden or disabled ?
Mehz
tharunok
Unfortunately, as of now, there isn't a direct setting to completely disable the Quick Panel on your lockscreen in One UI. However, you can limit its functionality by:
1. Disabling Notifications:
* Go to Settings.
* Tap on "Notifications."
* Scroll down and select "Notifications on lockscreen."
* Choose the desired settings:
* "Hide content when the device is locked": This prevents the content of notifications from being visible on the lockscreen.
* "Show alerts when the device is locked": This allows you to see that there are new notifications, but not their content.
2. Using a Secure Folder:
* If you have sensitive information that you don't want to be accessible from the lockscreen, consider using Samsung's Secure Folder feature. This creates a private space within your device where you can store apps and data that are protected by an additional password or biometric authentication.
IS_S24ultra
Thank you for the valuable suggestions.
Mehz
Orelse u can choose this off the lockscreen notification 1724613804338.jpg1724613804349.jpg
IS_S24ultra
Thank you for the reply.
I am sharing snapshot of the drawer.
Mehz
Not from here... go to setting then type notification u will get the options like did
IS_S24ultra
Thanks for the suggestion.
