S25Ultra
05-07-2025 05:52 PM (Last edited 05-07-2025 06:21 PM ) in
Galaxy SGot a question about the One UI 7 lock screen functionality.🤔
I'm curious if there's a feature or setting that lets us disable the pull-down action of the notification or quick settings panel on the lock screen. Or any third party apps that can help? 🤷♂️
Also, I know we can disable notifications on the lock screen, but they still can be pulled down. I want to disable the action of pull down itself in lock screen. So basically, if I try to pull from top on lock screen, nothing should happen.
Vedant3503
05-07-2025 06:11 PM in
Han if you edit in panel there is a option about edit panel aa jayega, automatically it also apply on lock screen
