How to calibrate battery? On samsung s20fe
(Topic created on: 07-29-2024 10:33 AM)
Ashutosh_595
Hey i am facing ghost battery problem and Battery draining problem very fast. In telegram someone suggest me to do battery calibrate. I dont know how to calibrate battery. And is it safe? Please share your thoughts on this
8 Comments
MR_PRIME
Better to go service center don't trust on any kind of troubleshooting steps also from telegram.
Service center will dignose properly and let you know for further steps.
Plz Accept solution clicking on 3dot right side nd Do follow for Regular Updates.
abhijithjay
Calibrating your battery is just a procedure to fully reset your battery. It may turn out to be helpful if your battery is not charging fully, phone switches off even if the battery isn't drained completely, and so on.
Here are the steps
*Drain the battery until the device turns off
*Turn the device back on and let it turn off again
*Plug in the charger and charge until the screen says "Battery full"
*Unplug the charger and turn the device back on
*Plug in the charger again and charge until it reaches 100%
*Unplug the charger and restart the device
*Repeat step 4 until the device shows 100% after restarting
*Use the device until the battery reaches 0% and the device turns off
*Fully charge the device without interruption
abhijithjay
The process is a bit long, so make sure you do it when your phone isn't in much use.
iamaksham
Battery calibration? It's new to me. According to me S20FE is launched 4 yrs back with Android 10.
Now this mobile is in end of life. And S20 FE is already had an all of its update.
What you can do is. Try factory reset it will remove all the files. It may help you a little but not like an new device.
SinghBipul
There Is An Option To Reset Battery Status ,, *#9900#,, It Works Or Not I Am Not Sure ,, Have A Try ,, And Look It Works Or Not..1722230889134.jpg1722230889158.jpg
owl123
Just replace your battery, wouldn't cost much
Oldy47
This is same as A Student didn't study for whole year and by studying last few days want to get good grades.
Your options.
If you used your phone for years. You can't do much with calibrating the battery.
Either reduce your SOT or change the battery
cs_member10
Dear Samsung Member,
As per your concern, we would request you kindly perform the following steps to resolve your issue by the given links.
Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
You can reset your device by following the steps in the link below.
If the issue still occurs, please visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
