Samsung Battery Calibration
(Topic created on: 02-04-2022 10:39 PM)
LegendofTomorrow
For all those facing battery issues. You may try this
1. Battery optimization starts 30 mins after unplugging from charger if device is left idle.
2. Uninstall/Disable apps which you don't use. No need to uninstall apps using adb. Whatever possible from app management is enough.
3. You may choose to use AI or not. If not using AI then put apps to sleep/deep sleep manually.
4. Best practice is to charge when battery is between 15 to 20% and unplug when 80 to 85 %. Sometimes you can full charge (like once a week)
5. Best practice is to turn off device for few mins once a week.
5 Comments
mHappiee
In 5. , Instead of "Switch off" for few minutes, you should "Restart".
Both does the same thing but there is a difference 😬
Yes there is a difference.. with power off ..there will be no process threads and clear any volatile memory. Also few mins will allow the residue energy to discharge from the electronic components.. generally speaking..
mHappiee
Hmmmmmm...
Ab_Heartsy
Expert Level 3
Hmmm..🤔, what's the difference ?
cs-member13
Expert Level 4
Dear Samsung member,
Settings > Select Device Maintenance/Device Care > Optimize > Optimize all options like Battery, Storage and Memory
Kindly turn off the smart features of the device and other connectivity features when not in use, which will eventually help you to reduce battery power consumption (smart features such as Motion gestures in advance feature and Bluetooth, Wi-Fi, Hotspot, etc.).
Please follow the below steps:
2. Tap on Bluetooth, Location/GPS, Wi-Fi, Mobile hotspot, NFC, etc. to turn off.
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Get help > Send Feedback > Error report).
Warm regard,
