Heating and slow charging issue in S23 after 6.1 update
(Topic created on: 04-06-2024 05:03 PM)
Senpaihitesh
Hi folks
After updating to One Ui 6.1 update this week I have experienced more fluidness in the UI as promised but there are two big issues that I am facing
1. Slow Charging Speed: After the 6.1 update, the phone is taking a lot longer to charge.
2. Heating issue: Also, average temperature of the phone is between 37 to 45 degrees on normal usgae which is not normal and was not the issue before.
Has anyone of you faced the same issue?
7 Comments
Shiva0509
Usually depending on outside temperature phone gets heated, also it's a metal body and small body so it's quite common to heat and also when it heats , it's just reduces the battery charging speed to balance it's heat, don't worry it's a temporary issue
goodthings
Kindly reset factory data with backup then try to it's again. If you like please accept as a solution it's help to others users also, click 3dots in my reply section and click on accept solution. Thanks.
JithinAjith
Settings 》Google 》Devices 》Turn off scan for nearby devices
Settings 》Connections 》More connection settings 》Printing 》Turn off default printing service
Device care 》Battery 》Background usage limit 》Deep sleeping apps 》 add apps
cs_member10
Dear Samsung Member,
Galaxy device slow charging issue: we would request you to kindly perform the following steps to resolve your issue.
Use a ''Genuine Samsung charger'' with your device
If you are using non-genuine Samsung charger, check device charging by using another Samsung genuine charger. (If available)
Note: We always recommend to use genuine Samsung charger for charging your device.
Check physical condition of USB cable
Check your charging cable (USB cable) for physical damage such as wear and tear, bent prongs etc. If it is damaged, then kindly visit your nearest service center to get it replaced.
Check charger functionality
Request you to check the charger functionality with a different device or try to charge the same device with a different charger.
If different device charging with the same charger:
It seems your charger is functioning, before getting into the mobile-related troubleshooting, I would like to know whether you are using a Samsung approved charger?
Note: We recommend our customers to use only Samsung approved chargers, as 3rd party chargers with different output rating may cause errors in the device.
If the device charging with different charger:
It seems there is an issue with your charger, kindly check the physical condition of your charger for any damage.
If damage: Issue might be because of the damage hence we request you to visit Samsung service center to get it replaced (Warranty not applicable).
If not damage: As we have tried with all possible troubleshooting and issue has not been resolved. I request you to visit the nearby service center along with your mobile and charger for a detailed inspection.
Check charging
If rating is 15W or above: Kindly try to charge the device in a non-inverter socket.
If you are using normal socket: As a safety measure Fast charging may not support, while you are using the device hence, request you to keep the device idle and check the charging performance.
Note: Kindly open Device care from settings > Battery > Please tap on three dots (more option) at the top right hand side > please select settings > enable fast cable charging.
For Android 11: Kindly open Device care from settings > tap on Battery > tap on More battery settings > Fast charging > Turn on.
Charge the device in switch off condition
Kindly follow the standard charging procedure. i.e; please charge the device in switch off condition for a minimum of 10 minutes.
If not resolved: (Removable battery) – Kindly remove the back panel of your device and check the physical condition (Bulge, Swelling or visible damage).
If the physical condition is not good: Request you to turn off the device immediately and please do not try to charge or tamper the battery also request you to visit the service center immediately.
Turn off Wi-Fi, GPS, Bluetooth etc.
Turn off unused functions like Wi-fi, GPS, Bluetooth & Location settings when not using them.
Please follow the below steps:
Step1: On the home screen swipe down the notification panel.
Step2: Turn off Wi-Fi, GPS, Bluetooth, and other connectivity features when not using them.
Close background running apps
''Multiple applications'' are running in the background of the device?
When running multiple applications, the processor processes more tasks and as a result, additional heat is released from the device. This happens with most electronic devices (even computers/laptops), including the devices of other manufacturers. Close all the background running apps when not using them.
Avoid usage of mobile phone during charging
Usage of the mobile phone when charging may cause slow charging issue. So we recommend you to avoid the usage of the mobile phone while charging.
Update device software (If Software update available): https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-smartphone-how-to-update-software/
Reset the device: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-mobile-how-to-perform-a-factory-res...
Galaxy device heating issue: https://www.samsung.com/in/support/mobile-devices/why-the-device-heats-up-during-use/
In case the issue still occurs, please register your concern in the Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
UPDATE A 34 5G
Software update a 34 5g
iamJSK
Yeh... I too have noticed heating issues on my S23 after the OneUI 6.1 update.  The Youtube videos (even the downloaded videos) while watching in landscape/full screen mode, the phone gets heat up within 5mts. Generally on OneUi 6.1, the phone has a tendency to get warm even on normal usage. Bcoz of these heating issues, the battery drain is much faster on OneUi 6.1.
