Heating Problem S20FE
(Topic created on: 03-03-2021 06:14 PM)
GSN
I had recently purchased S20 FE. and having heating problem in my handset from the 1st day please suggest what to do. I am a samsung fan and now feeling very disappointed.
16 Comments
Rohit9r
We all are facing issue
Exynos 990 is the reason behind it
Now we are trapped
Snapdragon Processors are far better than Samsung’s in house Exynos
GSN
Now what should we do bro
AjuGeorge
I don't think that there is a solution as of now. Only option left is to fine tune the software to reduce the heat, if possible
Rohit9r
Wait till the time.. Device learn battery usuage.
However don't expect good battery life from this device.
I am also regretting
Bad battery life
Samsung support will only provide you steps like reduce brightness, stop wifi scanning, adjust screen to 60 Hz etc etc.
Means we brought a device giving hefty amount and we can't use the device with all features enabled.
Samsung must understand that if we are buying a device, we will use it to fullest.
Even After so many maual changing
Issue will still remain the same.
If possible exchange it for better device in coming months or after a year.
Samsung S21 has slightly better processor
ie Exynos 2100
In my opinion always go for Snapdragon Processor device.
Notadeveloper
Yeah its not optimised well on the FE
Maddy210
we are trapped brother...better we can sign a petition as this is faced by every fe user having exynos. Samsung should listen to the customers.
GSN
yes bro something has to be done
anpin
i too have the same heating problem with my s20 FE and it is soo bad... why don't we all collectively do something about it
GSN
sure
