Heating problem
(Topic created on: 03-11-2025 08:34 AM)
prasanta8420
My Galaxy S20FE 5G getting hot with small task like Facebook Instagram etc.. I don't even play games.. and after that my phone's screen not work properly..it's stuck sometimes
3 Comments
goodthings
Kindly reset factory data with backup then try to it's again. If you like please accept as a solution it's help to others users also,click on 3dots in my reply section and click on accept solution. Thanks.
KunteAmith
Samsung phones heat up more then others especially during summer. Here are few factors that might be reasons for your problem.
1. Your are in poor network area which make phone work harder to send and receive data.
2. You are using your phone while it's charging. If yes your should remove your phone cover to help desipate heat faster.
cs_member10
Dear Samsung Member,
1. Turn off Wi-Fi, GPS, Bluetooth, and other connectivity features when not using them.
2. Decrease the screen brightness.
3. Close background running apps.
4. Uninstall the unnecessary apps.
5. Reduce long duration of graphics intensive gaming sessions as it may cause heating issue.
6. Avoid usage of mobile phone when charging.
7. Update software: Go to Settings > Software update > Download and install > Checking for software update > Software update available > Tap on Download > Downloading updates > Tap on Install now.
8. If the issue is still not been resolved, Reset the device:
IMPORTANT:
• For this:
• Open Gmail (https://accounts.google.com/servicelogin) > forgot password >Select ""try another way"" > Next > Enter a new password > Next.
Settings > General Management > Reset > Temporary cloud backup or External storage backup > tap on Factory data reset (This will erase all data, including files and downloaded apps)
If the issue still persists, after performing all troubleshooting steps, would request you to please visit the service center. Below is the link to find nearest service center
http://www.samsung.com/in/support/servicelocation/
