overheating issue with s20 fe
(Topic created on: 02-06-2021 08:57 PM)
kalponik
My phone is heating up a lot in the back top around camera bump area and on the front around earpiece area mostly just after few minutes of simple use. No gaming.  Just multitasking with several light apps. Phone specially getting more heated after 5/6  minutes of camera use. Any one with similar issues?  Anybody had issues solved after facing such problems? My one is 4g exynos 8/128 gb version
16 Comments
VanshJUDGE
brother its processor problem
VanshJUDGE
every exynos 990 phone have this ptoblem
Notadeveloper
Not every device, just FE. Not facing it on S20+. If it was there before idk. I have been using it since quite some time now, never faced the above ones. Just device gets a bit warm when multi tasking for longer durations
VanshJUDGE
brother this happens in note 20 ultra too
Notadeveloper
Idk then, its not happening in S20 regular series after latest updates
mbrahmam
yes my s20fe also
Maddy210
facing the same...better raise error in the customer support. but most probably it won't be fruitful.
karandriems
Check with clear cache partition, it might help you
Sowmiy
facing the same problem
