Galaxy S22 Plus - Phone is heating up and battery is draining quickly
(Topic created on: 08-14-2023 11:01 AM)
TeoMaelstrom
Hey, after the July update, I've been seeing a quick decrease of battery and heating up of the phone. Can anyone confirm if the case is the same with others and what can I do to address these problems?
8 Comments
umesh30
While gaming or normal usage??
TeoMaelstrom
Normal usage like browsing, listening music etc
pbpelik
Same here
Happening after latest update,
cs_member10
Dear Samsung member,
We acknowledge your query and apologize for the inconvenience caused to you and will surely assist you regarding the same. And please follow the easy troubleshooting steps which might help to solve the issue.
Settings > Select Device Maintenance/Device Care > Optimize > Optimize all options like Battery, Storage and Memory
Kindly turn off the smart features of the device and other connectivity features when not in use, which will eventually help you to reduce battery power consumption (smart features such as Motion gestures in advance feature and Bluetooth, Wi-Fi, Hotspot, etc.).
Please follow the below steps:
2. Tap on Bluetooth, Location/GPS, Wi-Fi, Mobile hotspot, NFC, etc. to turn off.
Please visit this mentioned link to resolve your device issue: https://www.samsung.com/in/support/mobile-devices/how-to-prevent-the-overheating-of-your-galaxy-devi...
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
Warm regard,
poteyp
Yeahh i barely get 3hrs with 120hrz
poteyp
Just on normal uses messengers fb tiktok
Pkhegde
Same this happening with my s22 plus. Also fast charging not working with 25w chanrger somehow. May be bcoz of heating of the phone
