Front camera object focusing problem on s22 ultra
(Topic created on: 09-11-2024 01:17 AM)
Easinislam
My Samsung Galaxy s22 ultra 5g has some issue in front camera.. Whene i take a group selfie.. It's Just focusing on subject, but other object don’t focus. Without subject its take a blurry image... Please solve this problem...please help me how to solve this problem
6 Comments
Easinislam
Please explain me, if anyone know
mohit121
I am currently experiencing a similar problem with my phone.
ThajP3
Just reset the app... In app info > storage > clear cache > clear storage > forcestop...
That's it... Most of the time it works....
PS: I'm also using s22 ultra..
Easinislam
Please check the image...just take clear image on subject, but objects does not clear 20240812_180828_1000000640_1723464510.jpg
ThajP3
Dude this is sensor alignment issue...
Just do the above steps... If it didn't works... Then you need to change the whole front camera sensor...
cs_member10
Dear Samsung Member,
As per your query, we would request you to kindly perform the following steps to resolve your issue.
Reset the camera settings: Home screen tap on Camera>Settings>Reset settings>Reset.
Clear camera application data: Apps>Camera>Storage>Clear Data
Check app cache: Settings > Apps > Camera> Storage > Clear Cache.
You can reset your device by following the steps.
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
