Fix color, contrast and laggy screen on s24 ultra
(Topic created on: 04-21-2024 10:55 PM)
Logout123
Plz fix s24 ultra following problems
1. Dull color, contrast
2. Increase touch sensitivity & laggy diaplay @60fps
3. Boost battery time optimisation
2 Comments
cs_member10
Dear Samsung Member,
As per your query, we want to inform you that the Galaxy S24 series model has been adjusted for colors and brightness for more accurate and comfortable vision while using. It has made some changes to the display technology to offer a more natural viewing experience, so you may notice differences in color depth when compared to older devices.
This concept of behavior on the display is an intended color adjustment and is not a defect of the product, so you can use it with confidence.
Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
Galaxy device touch issue: Remove the screen protectors and cover from the device once and check the issue after restarting the device.
Path: Press the power and volume down keys simultaneously for a few seconds.
Check space availability: Settings > Device Care >Storage.
Clear app cache through Device care:
Settings > Device care > Storage > CLEAN NOW.
Note: To delete files or uninstall apps you no longer use, select a category under USER DATA. Then, tick items to select and tap DELETE or UNINSTALL.
Reset the device Settings: Settings > General Management > Reset settings>Reset all settings to their default.
In case the issue still occurs, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
Logout123
No helpful
