Fingerprint not working on s24 ultra
(Topic created on: 07-08-2024 08:18 AM)
r2p85
Samsung must get some solution on fingerprint lock/ unlock of s24 ultra.
I tried different types of tempered glass cover on s24 ultra but all times. It doesn't work properly. I also tried increase touch sensitivity option from display. But doesn't work.
Samsung must get some solution on this, as it is high end phone . It is very hard to do in emergency situation.
12 Comments
Mayur000
scorpioMKH
I am currently utilizing a screen protector manufactured by Samsung and have not encountered any difficulties with the fingerprint unlocking functionality. However, it is worth noting that I have experienced issues with fingerprint unlocking when using screen protectors from other manufacturers.
cs_member10
Dear Samsung Customer,
As per your query, we would request you to kindly perform the following steps to resolve your issue.
Fingerprint sensor not working
If your fingerprints fail to unlock the phone, and you are asked to type in the lock screen password, follow the steps to resolve the problem:
Have you check your fingers:
Ensure that your fingers are clean and dry.
Note:
1: If the skin on your fingertips is peeling or cracking, or your fingerprint is difficult to capture, the fingerprint ID on your phone may not work.
2: If your fingerprints fail to unlock the phone while the phone is recharging, remove it from the charger and try again. If you are charging the phone with a charger and data cable from other brands when you use fingerprints to unlock the phone, they may interfere with the fingerprint sensor and cause the recognition to fail.
Clean the fingerprint sensor:
Clean the fingerprint sensor with a soft cloth. Make sure the fingerprint sensor is dry and free from any debris that may cause the sensor to be unable to recognize fingerprint.
Remove the Screen Guard /Screen Protector:
Samsung cannot guarantee compatibility with third-party products, as the thickness and structure of protective films or screen protectors may affect the performance of the fingerprint sensor. So if you are using third-party Screen Guard /Screen Protector remove it and try re-registering the fingerprint again.
Remove fingerprint and set up fingerprint again:
Remove the current fingerprint and set up fingerprint again. When you touch the sensor to set up fingerprint, make sure you set the entire fingerprint, including the outer area of your fingertip. Setting the entire fingerprint area enables successful fingerprint recognition with any grip.
Please follow the below steps:
How to remove Fingerprint:
Navigate to apps screen and tap on Settings>>Tap on Biometrics and Security>>
Tap on Fingerprints>>Tap on Fingerprint1>>Tap on Remove>>Tap on Remove again to confirm.
How to Set up Fingerprint:
Navigate to apps screen and tap on Settings>>Tap on Biometrics and Security>> Tap on Fingerprints>>Tap on Add Fingerprint>>Scan your fingerprint>>Place your finger on the sensor, then lift it off when you feel a vibration>>Tap on Continue>> Reposition your finger each time to capture the edge of your fingerprint>>Tap on Done>>Fingerprint added successfully.
Update device software (If Software update available): https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-smartphone-how-to-update-software/
Reset the device: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-mobile-how-to-perform-a-factory-res...
In case the issue still occurs. Please register your concern in Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
Samsung Customer Support.
