Fingerprint not working on s24 ultra
(Topic created on: 07-08-2024 08:18 AM)
r2p85
Samsung must get some solution on fingerprint lock/ unlock of s24 ultra.
I tried different types of tempered glass cover on s24 ultra but all times. It doesn't work properly. I also tried increase touch sensitivity option from display. But doesn't work.
Samsung must get some solution on this, as it is high end phone . It is very hard to do in emergency situation.
12 Comments
GOPINATH-R
Try spigen original tempered glass...
r2p85
Tried, but not work properly
MR_PRIME
I am also using with temperd glass and working totally fine.
Let me help you. Only fingerprint supported tempered will work with that because it had ultrasonic fingerprint sensor not digital. Many temperd you will find online will not work. Search offline. If you don't get let me know i'll help.
Plz Accept solution clicking on 3dot right side nd Do follow for Regular Updates.
r2p85
Plz suggest
MR_PRIME
Buddy you have two option through i can help.
1. Search in your offline area and make sure to ask will fingerprint work or not.
2. I can shipped to you from my market. (Don't get me wrng) this is only the way to help you. Otherwise it's all up to you.
GOPINATH-R
Try any other scarth gaurd like Samsung oe / spigen/ ringke/ nillikin or try near any malls for applying good screen guard...
There's the only option r there...
r2p85
Ok. Thanks . I will try & see
kumik
Bro..all are money minded.. spigen esr **bleep**.. everyone giving a piece of glass. Thats all.. don't get tensed.. I pasted 200rs tempered glass.. after pasting I deleted all finger prints and uploaded new.. it's working perfect..
Veergohel
Ensure both your finger and the screen are clean and dry.
