Faster Battery Drain after Started Using Modes & Routines.
(Topic created on: 02-16-2024 02:41 PM)
GALAXYECOSYSTEM
Hello Members!
Currently I am using my S24 Ultra. Just recently I started using the modes & Routines for my convenience and I realised that only after then the battery is draining faster. Because since the purchase and before using Routines I didn't face any battery drain issue.
For e.g. in normal night earlier my phone used to drain hardly 4 to 5%. But yesterday when I put it on Night Routine, the drains was around 15%.
Anybody here who have experienced battery drain issue after using "Modes & Routines" please share your valuable input.
Update/Resolution - The Google message app was eating the battery even though I wasn't using. Found out that through my interaction with a Samsung Executive. Disabled that app and since then didn't face any issues of battery drain.
"So it was not the Modes & Routines rather Google Message app being the reason behind my faster Battery drain".
Time to disable all the unnecessary preinstalled Google apps for which we have a Samsung alternative such as message, call, files, photos etc. from our Samung devices.
17 Comments
Darkvader12
Expert Level 3
Means is that when I open certain apps turn on mobile data otherwise it will be off
Truly appreciate it. Let me change certain settings and get back if I find any improvements.
leoo9989
Did you find any improvements
I'm also faced battery drain issues when I use routines
Yes. The battery drain was not due to the Routines but because of the Google Messaging app. I have disabled that application, and I haven't faced any battery drain issues since then.
I will suggest going to your battery and checking which application is consuming higher battery level. But, stay assured that routines help in saving batteries, not draining it .
leoo9989
Darkvader12
Expert Level 3
i unistalled the google messages through adb
Yash382
No bro i used a lot of routines but i don't faced battery issue
Don't use routines at night cause when u are using it at night it run in background and it will consume battery
Anuppp
Me too. I see significant battery drainage after using routines.
